Power steering problem
    Changed the alternator and had some problems with the belts being tight. Loosened the alternator belt and slapped everything else back together. I go to turn the wheel and the power steering belt slows and starts squeling.
    fyi
    I completely removed the power steering pump during alternator change.
    currently there was enough fliud in the reservior.
    what i haven't checked is whether the car will turn without power steering.
    help.
    fyi
    help.
    Sounds like the belt is too loose. Tighten it up a bit and it should be fine.
    00 Jeep Grand Cherokee 4.7 V8 4X4
    92 Honda Accord LX
    95 Honda Civic CX
      did u use Gunk brand HONDA Power Steering Fluid...?
        On a tangent, Corey, the accessory belts you did when you switched out that tranny still squeal on a cold startup, even after I've loosened the PS belt some. Is this indicative of something else?
        Former: 90 Accord EX Coupe, 93 10th Anniversary in Frost White
        1985 Volvo 245 manual [IPD lowering springs, IPD sway bars, OEM Virgo wheels, 1977 quad round headlights, 1978 grill]
        2001 Mazda B3000 SE 4x4 extended cab [stock except for CB radio]
        2008 Ford Escape XLT [bone stock]
        2015 Toyota Prius Three with solar roof [rear diffuser, Vision Cross wheels... cheaper than steelies!]
          thanks cory. although, answer the phone next time.
            Why did you loosen them, that will just make it worse. If they squeal, it means the belts have stretched and are too loose. Either that or its because we used those cheap Autozone accessory belts. (don't worry, the timing belt I put in there was OEM at least)
            92 Honda Accord LX
            95 Honda Civic CX
              Did you try calling me again since I talked to you earlier?
              92 Honda Accord LX
              95 Honda Civic CX
                ok. so squealing belts = too tight or too loose?
                i'm thinking i should have tightened them to hell since that how they where when i took them off.
                currently the alternator belt is very loose but no squealing. the ps belt on the other hand is loose and squels when the wheel it turned.
                be damned if the biggest problem I have is with drive belts.
                  squealing belts = too loose
                  1993 Accord Ex Coupe
                  -1999 USDM H22A4, M2Y4
                  -JDM 17" WedsSport RS-5
                  -BFGoodrich T/A Sports 215/40/17
                  -JDM Fujitsubo Legalis-R Exhaust
                  -D2 Coilovers
                  -JDM Headlights
                  -Suspension Techniques Rear Swaybar
                  -Axxis Metal Master Brake Pads
                  -Recaro Seat
                    off to tighten them.
                    thanks y'all. Problem Fixed.
