thurs car was fine. Then I got the bright Idea of taken my 4-2-1 cast header and downpipe off the a6 and put it on my a1. the a6 downpipe has o2 at its rear not like my stock mani, right there! Anyway the one that was in there I found to be faulty, had cel in car it came from, and so i hooked it up in mine to find this. Next day I swap my mani's o2 for the other and I lengthen that harness! Turns out the plug from the engine harness of my a1 is Identical to the plug coming from the old o2 from the a6 header (with the exception of the wires colours)! So I connect it raw, cel goes away but I have idle surge still! again it was fine on thurs before the swap! So i go 500km and spend the night hangin wit my friend, and wake up the next morn to tackle this task. I notice a leak, fuel, from the #4 cyl injector so I buy another, and replace it leak is now gone but car still surgeing and is idleing on only three cyl! I pull the fourth wire it which made no diff(no change in engine at all!) has spark and the plug is good! It runs...ok movin except the surge, I have tried the fiv/vacuums are good, swapped the ecu! I am lost need help bad! have Reset the ecu! Map? anybody have any idea? thanks!
trial #3 with a nice fmic! Dsm setup, and so for that ill need a compression test anyway! Peace
It was none of the above! It just so happens that the gasket where the intake meets the head, had blew out a piece right above/behind that injector, thus the surge, and the reason it was fine on throttle etc. Thankfully my dad and I sprayed some starter fluid around the intake gasket areas to find the hole then we see it! I also had the one left over from my rebuild, cause we did not need to seperate the head then. My car is normal again! Now its time to get my turbo rebuilt so I can complete trial #3 Peace!
