I just got a new alternator probably a little less than a month ago, and everytime I start the car the belt squeals. It used to squeal loud as hell then I tightened the belt and it alright for a while. Then like a week later it started squealin loud again. I got a new belt and put it on and the squeal of death when away, but it still sueals very lightly when I Start the car. Any ideas what the problem may be and how I can fix it?
Alternator problems
is the tightening maxed out??
does it do it only when its cold or first engine start up...
it can be that you should of went with one size smaller belt, or that its a *** belt....What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Well your not gonna get any help if you dont reply to your own thread like I said what kind of belt did you use? If its not a honda belt that could likely be the problem autozone belts are notorious for squealing, if it is an OEM belt then its the tension, too little or too much tension will cause it to be noisy so get a straight edge and a ruler and come back with your measurement of slack.
Originally posted by TysCb7Well your not gonna get any help if you dont reply to your own thread like I said what kind of belt did you use? If its not a honda belt that could likely be the problem autozone belts are notorious for squealing, if it is an OEM belt then its the tension, too little or too much tension will cause it to be noisy so get a straight edge and a ruler and come back with your measurement of slack.
Originally posted by F22-GURUAre you sure it is the Alternator Belt that's causing the Squeal and not the PS or AC Belts.
I would do as Guru says . chk the p/s belt to make sure it is not loose......if belts are ok,, remove the alt belt and run the car see if noise is still there , if it is , you got a different issue, if no more noise. spin the alt by hand and see if it is noisy you might have got a bad altenator , if alt is ok, than , that leaves only the belt, make sure it is properly installed in the grooves . i have seen people miss a groove in the crank pulley.. if installed ok the only thing left is the adjustment ..Nice Asses I Like
Smart asses I don't
