clutch qustion
    clutch qustion
    ok guys check it out when my car is off i can get in to gear no problem but when my car is on and running i cant get it in to gear, could this be a clutch problem or could be a tranny.
    You check your clutch master cylinder if its full? Follow your clutch pedal up and see if you see a wet spot. If you do your Clutch master cylinder is bad.
      check your pressure plate, that's my guess. had the same problem with my prelude and it was the pressure plate
      1996 Jeep Grand Cherokee Laredo
      4.0L I-6 2WD
      293k miles, still running strong.
      Freshly rebuilt transmission.
        if the pedal feels normal.. might guess would be pressure plate issues as well.......if pedal has a lot of travel ,or will not spring back up.. you might to look at an hydraulic leak,,
        clutch master, slave cylinder, hoses,
        Nice Asses I Like
        Smart asses I don't
