Diagnostic help needed!
    My '03 Accord EX coupoe has a couple problems, any idea why?
    1) Engine stalled while cruising between 40 - 50 mph - This happen twice in a month. The engine would just get cutoff, all the gauges, electrical system, stereo is still working. I shifted to neutral and restarted the engine within seconds. Spark plugs, distributor caps, wires, and fuel filter have been replaced.
    2) After replacing stock struts with Bilstein HD, it appears like we have raised the ride height by 2" !
    '93 Accord EX Coupe
    Bilstein HD Struts
    DC Sport F/R STB
    Perforated Wheelskins
    K&N drop-in air-filter
    more to come...
    Sounds like the ignition switch....very common on 4th gens. The only way to check it is to remove the upper and lower steering column covers and check the ignition switch terminals on the lock cylinder. If the solder connections are melted, the switch is bad and must be replaced.
    00 Jeep Grand Cherokee 4.7 V8 4X4
    92 Honda Accord LX
    95 Honda Civic CX
      Take it to the dealership and have it looked at. If you have a 2003, you should be able to have them fix it for no cost, or at least see where the problem is at.
        If ur talkin 03 then go back to the dealership. If its s 93 then its probably your ignition. Mine went bad about 2 years ago. It cut off and I couldnt start the car because the ON position was shifted back. The only way I got home was to start the car up, and pull it all the way back to the ACC position. I think the part was about 60-80 dollars. Pretty easy fix. Hope you get it workin.
        Formerly 91AccordExR33
        11.68 @ 127mph
        417whp/375wtq
        Sold: 8/2016
          lol when that shit happent to me i had to drive with one hand on the steering wheel and the other hand keeping the key in a possition so the car can ran.lol that shit was funny. and i did a fuck up mistake when i went and bought a new one at the honda dealer for $87 shit i could have bought one at a junk jard for $15 shit that was a real fuck up
            Re: Diagnostic help needed!
            It's '93 CB7, not an '03 gen 7
            Originally posted by OldHorse
            My '93 Accord EX coupoe has a couple problems, any idea why?
            '93 Accord EX Coupe
            Bilstein HD Struts
            DC Sport F/R STB
            more to come...
              It happened again yesterday twice in a roll. I was pulling up hill with ~ 1/4 tank. The engine suddenly cut off. Again the electrical system was fine, radio was still playing. I pulled over, and was able to restart rightaway. After another block or so, it did it again. I was able to restarted it again. Thinking it was fuel related, I filled up at a gas station nearby. Afterward, I ws able to drive 25 miles on the streets to get home. I don't think it's the module because I don't have to hold it, and this occurs while the car's in motion. Any thought?
              '93 Accord EX Coupe
              Bilstein HD Struts
              DC Sport F/R STB
              more to come...
                It could be the fuel pump or the fuel pump relay acting up. Run a test on them both. The Haynes manual shows you how. You should also test your alternator as it could be losing its ability to hold charge. Start the car and then disconnect the battery and if it dies out then you've got a bad one. And I've also worked on a car with a bad ignition coil. It will overheat and stop working but once it cools down enough your car will start back up and run fine until the coil overheats again.
                  I was considering a fuel line flush. I actually have not thought about the alternator nor the ignition coils at all. I can always restart the car with in a minute of stall, could the coil cool down that quickly? if the alternator is bad, wouldn't the battery go bad quickly?
                  Thanks for your reply.
                  '93 Accord EX Coupe
                  Bilstein HD Struts
                  DC Sport F/R STB
                  more to come...
                    I talked to my mechanic today. He also think it's fuel supply issue. He suggested that I swap out the Fuel pump relay first since it's easy and less expensive. If that does not work, he think we should replace the fuel pump. I have 135K miles on my '93 EX. For those of you with higher mileage on the CB7, whed did you had to replace your fuel pump? Would you guy recommand original Honda parts (~ $280) or other cheaper alternatives?
                    Thanks
                    '93 Accord EX Coupe
                    Bilstein HD Struts
                    DC Sport F/R STB
                    more to come...
                      go with oem parts because there better quality and last longer,honda knows more about hondas than anyone else.good luck.
                        Thanks!
                        '93 Accord EX Coupe
                        Bilstein HD Struts
                        DC Sport F/R STB
                        more to come...
                          Car stalled 5 times while idleing during warm up. What could it be?
                          '93 Accord EX Coupe
                          Bilstein HD Struts
                          DC Sport F/R STB
                          more to come...
