NGK or MSD
Spark Plug Wires???
Ok I seriously doubt your car starts better in the morning, unless the old ones you had on were fouled out. The thing it will do for you is give you a lil better gas mileage, perhaps increased acceleration (depending on other ignition mods), and less misfiring at the higher RPM's.Originally posted by Accordlxi got Ractive 9mm and it does make a differents..my car start fast in mornin..even in cold ass mornin..I crank it and its alive just like(snap finger)that!..but i took it off and use my OEM one cuz it look nicer....
there is nothing i have seen that is better than stock, as far as performance or long life. i have never seen a set of aftermarket wires last as long as stock ones. i usually see aftermarket ones start failing within 25k-30k miles with hig resistance. but for some reason stock wires that have come off of a 145k mile accord still ohm out nearly as good as new.
