Would removing the ceramic coating significantly reduce the performance of the header? Also what would be a good way of removing the ceramic coating?
ceramic coated header
Originally posted by pnoycb7Would removing the ceramic coating significantly reduce the performance of the header? Also what would be a good way of removing the ceramic coating?
Huh??
The easiest way is by putting a set of Non Ceramic Coated Headers On.
Why on god's green earth would you want to do that anyhow???
i asssume he wants the shiny look, therefore, i would just get a new header that is stainless steal rather than ceramic coated. Or the ceramic is pealing and the header is starting to rust a little in which case i would just paint the thing with high temp paint. In either case, i wouldn't be sanding down the ceramic on the header.Audi A4 2.8 Quattro Sport
