I know that there is a special tool fro removing O2 sensors. But I was wondering if there is any other tools or methods to remove and replace them. thanks
O2 Sensor removal
A wrench but you risk rounding off the bolt if its stuck on good. Plus a lil penetrating oil would help too.
You can also try making your own =O but it prob wont last long maybe one time use if your lucky.
a 22mm. wrench. but good luck and be careful. the o2 special tool socket is highly recommended.Originally posted by jtek24I know that there is a special tool fro removing O2 sensors. But I was wondering if there is any other tools or methods to remove and replace them. thanks
Fast, easy installation or removal. Removes and installs oxygen sensors on computer engine controlled vehicles this easy:
1. Disconnect sensor wire harness.
2. Slide wire through slot in socket.
3. Use 1/2" drive ratchet or wrench.
Designed for use in hard-to-reach places.
May be used with torque wrench.
Heat-treated, thick walled socket.
You can use a regular open end wrench or even better, a flare wrench! That's what I used. Looks like a 6 point box end wrench with one of the flats cut off. Works like a charm. But like was said earlier, lots of penetrating lube!Originally posted by Junior SmurffNevermind guys, google search works wonders!
I don't have road rage, my car just goes faster than yours!
Accords are for winners. And Grandmothers. But mostly winners.
I have grown so Tired of Internet Illiteracy. Please learn proper spelling and grammar. For your sake and that of your children.
PB BLASTER spray and a 22mm wrench! and have at it! make sure when u put in the new one to put some antiseize goop on the O2 threads..
SeanF22a1-->F22A-->H22A-->auto-2-5spd-->K20 6spd-->F22C 6spd RWD-->4G63 6spd AWD-->K24 6spd????
Sold to: blackice, Myothercar, Rennat, Ilikebigbutts, HA91, DA92CB7, accord91lx, Cb7GHOST, Gemini, whiteaccord92,Warudakumi, jhondayaaj
Bought from: 93twodoorLX, Datmofo, g7kobayashi, accord_inspire, Accord SiR, Kurobei, UK-Accord, phreakish93, RENR, k-mart
