Anyone have an idea of why the D4 in my car is blinking, only does it once the car is warmed up.
D4 blinking?
do a drain and fill using honda atf ONLY and then go a head and check all wiring on the tranny casing if not check the tcu,and d4 is blinking check at high speed if u feel the car is in overdrive on the highway and everything is ok i would go a head and do the drain and fill no flushes using honda atf only and they should give u a washer when u do the drain and fill 2.5 quarts it takes when u do the drain and fill
add 2 quarts start up car shift from p-1 slowly letting the fluid run through tranny and keep doing it then let it run and add the .5 quarts while its runninthen repeat park-1 letting all sgufts click in then change it again in one month ,but check all electrical component on tranny casing and last check tcu
(\__/)
(O.o )
(> < ) This is Bunny. Copy Bunny into your signature to help him on his way to world domination!
