my boy is throwing a code 43 in his accord, which should he replace first? fuel filter? it sat in the hot sun all day today and would not start for a while...anyone know?
code 43...which first??
Originally posted by xfactortype1code 43 is usually an oxygen sensor. fuel filter is cheap and easy as well.
a clogged fuel filter will usually trigger a code 16 a well..for fuel injector circuit.
itll be triggered cuz no fuel will get to injectors..rendering malfunction.
hope it helps
tom
Where did you dig that one up from?
You don't seriously believe that do you?
i fucked that up good..sorry
let me try again
code 41 is for heatred oxygen circuit..usually meaning sensor is bad.
code 43 is usually for fuel system supply(i.e fuel filter, fuel regulator, or fuel pump, fuel relay), but it can also be for heated oxygen sensor.
that was from two posts above..
code 16 is for fuel injector circuit(i.e fuel injector, injector resistor, ecm, and main relay)
thanks for catching that..
