ok here is my problem in the drivers side front when i turn the wheel there is a sorta binding creeking noise when i turn once and while it seems to be gettign worse and i cant seem to put my finger on what the problem is
it sorta sound like when a door opens that creeking noise and how it sputters buts it loud any clue what it maybe ,im thinking its lower ball joint or outer tie bar those are the two im leaning towards its not the wheel berring i just got that done and im gona go into more checking calipers brakes and so on ,could this also be making the noise the belt to tight maybe i dont know just think any possible thing that could be rubbing,binding anything in there and i also checked the plate behind the rotor but that wouldn make a more scraping noise or grinding ?????????????????
but just check around there while some one turns the wheel so u can find out what the fuck is the problem!!!! keep us posted if u found out what the problem is!!!!
