I replace my front mount and its now not vibratin in Reverse no more..but it still shake a lil at stop and when i Used power window it shake even more then stop...wierd or what??? any ideas.thnx
Wierd..My car vibrate when using elect
I DOn't Necessarily Think It Is A Motor Mount-
The guy is saying that his car "vibrates" when he uses the electrical components like power windows. If it were a bad Motor Mount then it would vibrate all the time.
THe problem is that the guy is saying "Vibration". What is really happening is that the idle is dropping making it run a little rougher. I agree with accordafafair. What he needs to do it pull of his Negative (-) battery cable (the BLACK one) and take a post cleaner or metal brush and scrub down the battery post and ring that goes around the post to get any corrosion off then BATHE the post and ring in Rust Penetrant/Lubricant and reattach. This is what I did... and it allows the Alternator to adequately judge electrical draw. If that doesn't work make sure your idle speed is @ 750. If it is too low adjust it higher.Why? Because... Life Happens @ 4500 RPM
Frost White CB7 Member 31
