clutch help! (pics)
    clutch help! (pics)
    which way does it go?
    i forgot....
    SOLD!
    the clutch casing should be able to bolt up to the flywheel nice and flat, not sure if that will do it if you flip the clutch over the wrong way.
    Either way, just make sure the clutch pads will be touching the flywheel. And I woulda changed that clutch while it was out IMO, or at least cleaned it up
    edit: pretty sure its the top one.. bottom would always have that extended part touching the flywheel.
      It looks like the side that has 785 faces the flywheel.
      YouTube Clicky!!
        785 faces the slywheel becuase the other side if it where up to the flywheel on the tranny the thing probably wont fit with that huge bulge in the way wherefor it wont make contact wit it in order for you to bolt it on there. But if you turn it where the 785 it looks like the pressure plate bulge thats stickin out the otherway othe other side it looks lke it will fit becuase i has that space for it.
          got it... tranny is on.... never want to do that again..
          SOLD!
