1. Hey everyone i have an 93 accord LX. i was just wondering for everyone that has the same car. does your fans every stay on or turn on after you turn the car off (when taking the key out?) if not... then what would be the problem? (Had the car for a yr. fans never kicked in till i did a flush and changed the thermostat (live in buffalo,ny so its cold and now its turning on after i turn it off)
2. Also.... Most cars have Fan Clutchs to tell the fans when and when not to turn on. what does the honda accord bring? cuz i know its not called a fan clutch..
3. Also.. is it normal for the top raditor hose to get warm and hot when you first warm up your car and the bottom one that goes from the Thermostat to the radiator stay cool (or not get as hot as the upper one) or there suppose to be the same temp?
Three quesitions if you people can answer them in that order.. thanks so much
Tony
Tony
my other accord did the same thing it just kicks in so it will cool down your car but i got to admit it is pretty emberasing to hear it go on once you get out of your car LOL but dont worry bout its all good!
