Torque specs for Tranny?
    Hey,
    What are the torque specs for the Tranny and the Clutch?
    Thanks,
    -Lam
    CLUTCH COVER 6 X 1.0 mm bolts 12 Nm (9 lb ft)
    PRESSURE PLATE Mounting Torque [1] 26 Nm (19 lb ft)
    [1] Tighten the bolts two turns at a time in a criss-cross pattern.
    TRANSMISSION TO ENGINE 12 X 1.25 mm bolts 65 Nm (47 lb ft)
    RING GEAR Bolts 101 Nm (74.5 ft. lbs.)
    SHIFT CABLE BRACKET 8 X 1.25 mm bolts 22 Nm (16 lb ft)
    TRANSMISSION BRACKET TO TRANSMISSION 10 X 1.25 mm nuts 39 Nm (28 lb ft)
    MOUNT TO TRANSMISSION BRACKET 10 X 1.25 mm nuts 39 Nm (28 lb ft)
    MOUNT TO BODY BRACKET 12 X 1.25 mm bolt 65 Nm (47 lb ft)
    REAR MOUNT BRACKET STAY 10 X 1.25 mm nut 21 Nm (15 lb ft) 10 X 1.25 mm bolt 39 Nm (28 lb ft)
      Wow bro... Thanks a bunch...
        np...ive done my clutch swap plenty of time...so god speed.
