OK, Are Fram Oil Filters any good? I did a search on this, and I get mixed emotions from all of you. Are they or are they not a good oil filter to put on my CB7?
Oil filter (Fram?)
I would only use it if it was the last filter left on earth. That, and I would change my oil every 3k, period.
Its probably fine to use if you do got for 3k changes. I would only do 3k, regardless of whether you run synthetic or dino.
Personally I use S2000 OEM filters as they're made in Japan. Watch out as the OEM filters sold for Accords are now made by Fram. Not sure what that means as far as quality. I hear they are different, specific for Honda, but not sure how different. Personally I run about 6k using the S2k filter and Mobile1.
I paid about $6 or $7 each for them. Just ask for an S2000 filter. Year doesn't matter as they're all the same. Yes, they fit just like stock. I use them on my H22 and the H22 and F22 filters are the same anyway.
Frams are bad because of their construction. Less filter material and poorly designed spings/anti-drainback valves. Google for some oil filter comparisons and you'll get more info.
Originally posted by aero3685
nice, i think i'll be doing the s2000 filters then. I always do my oil @ or before 3000miles. So these will last for 6000? And the oil also will last 6k?
they are OK...but i mean there are alot there out there that are better made and cheaper than fram.
supertech is cheap but good, ac delco, purolator, etc.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Originally posted by NutBucket
Personally I use S2000 OEM filters as they're made in Japan. Watch out as the OEM filters sold for Accords are now made by Fram.00 Jeep Grand Cherokee 4.7 V8 4X4
92 Honda Accord LX
95 Honda Civic CX
BTW...my personal opinion, a filter is a filter is a filter....they all do the exact same thing. As long as you are changing your oil every 3K miles anything will work fine. The only reason I use the Honda filters is because I get them for free.00 Jeep Grand Cherokee 4.7 V8 4X4
92 Honda Accord LX
95 Honda Civic CX
