automatic downshifting like standard?
    about 2 weeks ago, I noticed when I slow down and my car starts to downshift, its like im downshifting a standard, it only seems to do it right when its first started and goes away once its heated up, its not very bad but I can notice it. one day last week after I worked on my car it was very bad. does anyone have any idea what would cause this?
    My Members Ride Page
    Well its most likely trying to help your car slow down obviously. Its normal but when you mean bad how bad. I drove a 1990 DX and it was a bit rough when going down the gears cold but was fine when it warmed up a lil but thats normal. How long has it been since you changed your ATF?
      well my fluids perfect, Im very anal about everything in my carif somthing makes a noise or if it shifts funny I get worried, its not noticible at all now. but teh other day the one time it was bad, it was liek slowing down and somone downshofting by hand with the engine rpms goign up, eevrytime it shifted down
        I'd say consider yourself lucky. I can slow down to 25mph and my shitbox will still be in 4th gear. I think it likes not revving and only putting out 50hp.
        I'm gonna light it on fire when I pull it out.
        Metal Metal and more Metal!!!
        How much does your wheel/tire combo weigh? Post here!
        -=Suicide Crew Member #1 (only member so far)=-
        MY RIDE
        "I was hoping the Wolverine would finger one of those Japanese girls and then extend a claw into her b hole just for fun, BUT that never happened and I was extremely unsatisfied with the movie because of it." -Macaqueistrong
          Check the throttle control cable that goes to your transmission. If it is broken, sticking, or not synchronized, it can cause rough downshifts when stopping as you are describing. If the cable sticks or is too short, the trans. will think you still have the gas pressed. I would lube it up and adjust it a little on the loose side for smoother shifts. (Not too loose or your clutches will slip) Also, there are about 3 codes from the TCM that can be set but do not trigger a D4 light. One is a code 15 which is the mainshaft speed sensor. If that is bad, you may experience hard shifts. Remember that a little bit of downshift can be felt from a perfectly working trans. Jump your service connector and see if you have any codes tho.
            i had that it was around like 20 mph when the needle was dropping and it gave the car a little jerk i did a drain and fill and it was gone so try servicing the tranny and hopefully it will be good
            (\__/)
            (O.o )
            (> < ) This is Bunny. Copy Bunny into your signature to help him on his way to world domination!
              yeah I probalby shoulda said my d4 is burnt out, its seemsto be working fine now
