battery terminal not tight
    well both my battery terminalsare ***,there loose even when i tighten them down very tight,i have washers jamed in each terminal between the post and the termianls themselves,anyone got any tricks to fixing this,or should i get new terminals.thankx
    im guessing its the terminals coming from the car, not the ones sticking up from the battery... i really dont know how safe it is sticking washers in there, that seems too bootlegged to me. i say get a new pair of terminals, they arent expensive.
      wear would i get new cables?and how much are they?thanks,do they just bolt on to the car?
        find a battery shop and buy some terminals from them. they will use this HUGE crimer to crimp it to the wire, i did that...my buddie owned the place..and gosh this terminal is better than stock..ALOT!! and it wont corrode cause of the material its made out of.
        or do it yourself, but the crap at kregan isnt the best.
        Retro!
        Hater
          just buy a terminal and install it! No big deal....no more than 20 bucks.
          just do it right, electrical fires suck
          Noobie my ASS.
            Do you have those little anti-corrosion felt washers on your battery posts? If so, try taking them off and see if the cables can be tightened. If the terminals aren't completely seated all the way down on the post, they won't tighten properly.
            00 Jeep Grand Cherokee 4.7 V8 4X4
            92 Honda Accord LX
            95 Honda Civic CX
              You can get ones at Wal-Mart for like $5 for the pair. All you do is cut your old ones off, strip the wires, and used the "nut and bolt" type clamp and clamp it right onto your wires, then tighten to battery. Walla!
              My song of the week (or till I change it): Snow Patrol - Take Back The City
                i got a walmart one for my positive terminal,and it has 2 wires(the terminals)one is huge and the other is small,i think the smalls a ground but i would like to get brand new positive and negative terminals.wear would i get them cheap.thanks
                  well i got the terminal that was loose tight enough,i want to get2 newcables sometime in the near future.
                    Originally posted by fizzbob7
                    it's "voila"
                    lol
                    I will make a note of that for next time
