auto transmission reverse shaking
    everytime i put my automatic in reverse the whole car starts shaking heavily. Do i need to do a tranny flush, or do i need a new trani all together.
    PROFESSOR
    Edison, NJ
    green-T
    92 accord LX
    BEFORE, PRESENT, AND AFTER PICS COMING SOON!
    (FROM RICE TO NICE)
    My ride
    Hit up myspace
    Might wanna check out those engine mounts. Sounds like they might have gone out on you.
      yeah it's most likely your engine mounts. it's normal for the motor to vibrate more when under load. a change of transmission fluid wouldn't hurt though but use genuine honda automatic transmission fluid when doing so. good luck!
      1cor10:31
      - 92 LX coupe
      - 96 EX wagon (sold)
        Yes sounds like the front mount=torque rod. As noted:
        http://www.jacobgood.com/data/TSB_IDLE.pdf
        '92 Accord LX Sedan--Bordeaux Red Pearl --OEM--279k Daily Driver
        EX Lip & Alpine OEM single CD Player. No more useless pocket!
          yep its the motor front motor mount..i just replace my and its fix the R sakin prob...
          MY 1n2 CB7
            This is the first time this has ever been covered.....
            http://www.cb7tuner.com/vbb/showthread.php?t=27485
              on the money
              the engine mounts never even crossed my mind, those things are so beat to sh*t. such a simple problemn that could have easily been avoided months ago. am i really the first one to cover this subject. well thanks for the help once again peeps. just another step closer to hittn the streets again thanks to cb7uner.com
              PROFESSOR
              Edison, NJ
              green-T
              92 accord LX
              (FROM RICE TO NICE)
              My ride
              Hit up myspace
                I noticed last nite i have this problem too now. Also a couple weeks ago I have been feeling vibrations to the gas pedal upon accelerating. Could this be related to a bad motor mount?
                  my 90 auto shakes the same way but the motors are good what could it be
                  could it be the torque converter plus honda said the syncros in the transmission
                  could be out and they said i might need to rebuild my tranny what do u guys think
                  H22 fund = 3000 hopefully soon My Member's Ride Thread
                  Canon XTI | 28-135mm IS USM | 18-55mm kit lens | 50mm 1.8 II
                    Mmmm.... APRIL FOOLS... JK
                    It could be your front or rear mount. The rear mount is filled with hydraulic oil that works on vaccuum. It stiffens or loosens to comfort the ride, but keep stiff so it shifts "smooth" also. The selenoid is often the part that goes bad on em, and the engine will rock when you put it into gear, and vibrate in D3/D4/R/N. It could also be that torque strut mount mentioned before. Its something you wanna look into though...
