need to charge my a/c....is this good ?
    i need to recharge my a/c for the first time.....
    is this good?
    http://www.id-usa.com/product.asp?CID=28&PID=217
    or is there something else out there that you have all used which is better?
    thanks....
    '93 LX Accord Anniversary Auto
    66K Miles (yes, only that much) and no rust!
    Usually a retrofit consists of changing up your fittings since the 134 fittings are bigger. As for the refrigerant you will have to find a place that will drain it all out.
      went to 2 different mechanic shops by me in NJ.....
      one guy asked $300, other guy asked $320.....
      breakdown was:
      2lb of freeon @ $65.
      labor (2hrs) @ $140.
      retrofit kit @ $125.
      are these fair prices?
        Find some Freeze12 and put that in your AC system. This way you dont have to do a retro fit. Its Legal in the US and its r12 without the dangerous carbons in it. It can be put into a r12 existing system without problems.
        freeze12
        WHY ARE HURRICANES NAMED AFTER WOMEN? CUZ WHEN THEY CUM , THEY ARE WET AND WILD AND WHEN THEY LEAVE... THEY TAKE YOUR HOUSE, YOUR CAR AND YOUR MONEY....!
          wow! two hours? It takes me 15min to recharge mine. All I did was buy this tool that grips around the refrigerant, and punctures the side of it. It has a line that hooks up to the existing line in our cars. I think it was fifteen bucks + refrigerant. If you want I will take a pic of the tool.
          Every Knee Shall Bow-Isaiah 45:23
            Maybe the labor rate was including evcuating any remaining R12 prior to the retrofit. If its the dealership that would also include a new receiver/dryer.
            '92 Accord LX Sedan--Bordeaux Red Pearl --OEM--279k Daily Driver
            EX Lip & Alpine OEM single CD Player. No more useless pocket!
              R12 nowadays is more expensive than 134. Its better to do the retrofit. The tool casey speaks of is basically a clamp that punctures the refrigerant can and you connect the tube to the low pressure side of the car. Im not sure how much A/C normally run around where you are. And yes it takes quite a while since they draw a vaccuum to make sure all of the refrigerant and oil is taken out.
                yes, that 2hrs included the whole draining of the a/c along with the retrofit part of it....
                so, am i stuck with this $300 bill or can i drain, retrofit and charge on my own??? just use the freeze12?
                  so, since this is a first time charge.... it needs to be drained....which is something a mechanic shop must do and not an avg joe like me?
