Situation:
Battery has full power. Ecu power is clicking on and off randomly and recieves partial power. ECU led remains off when recieving partial power and engine lights are dim. The starter won't crank via ignition switch.
What Happenned:
A fuse should have blown but didn't. I saw smoke, most likely from a couple burnt wires.
The Cause:
I tried to start the car up off the charger set on 50 amps. ( I knew I should just let it charge the battery)
My Exploration:
When I powered up the car from under the hood (hooked up a power source directly to the fuse box) the ECU got power... Fuel pump kicked on and everything. Starter turns from under the hood. Car will run when powered up directly from under the hood.
To Be Deduced: ECU power source is shorted somewhere between the cabin and the hood. Since the starter and ECU power source went at the same time, its highly likely the short is at the same location. I have not went indepth with the schematics to find a connection between the starter and ECU power source. I am ruling out a break near ECU fuses. The ECU and starter must share some sort of switched ignition power. This has to be where the break is.
Its raining hard. If it weren't, I would be outside finding this damn short.
Any input is appreciated. Just no mis-info, like main relay, ignition switch, etc... Those are not related at all to the problem. Its a bit more complicated than just replacing a part.
What Happenned:
The Cause:
My Exploration:
