i looked but did not find what i needed,i am in the middle of changing my tranny fluid and i found the drain bolt,but i cant figure out wichone is the inspection bolt,i know it has a square recess in it but theres 2 bolts with a square recess ones got a big square the others got a littler one,wich one is it because i need to finish this before i go to work,thanks.
changing manual tranny fluid.
i changed my fluid,my tranny fluid plus my engine oil/filter.no leaks so far and the idles fixed,i bought three quarts of honda mtf and i only put 2 full quarts in,is that enough i felt oil when i put my finger in the inspection hole,i just dont want to hafta get under there and add another quart.so is 2 ok.thanks
