distributor bolt stuck
    Well I was thinking of advancing the timing a bit, got the top and the one near the firewall out no problem. But can get the front bolt out. I even CRACKED my socket.....lol
    So is it easier to remove it when the engine is hot or cold?
    I did it in between....warm to the touch
    -Henry
    Great achievements result from great effort
    Got a picture? I always remove mine when my engine was cold.
      Try spraying it with PB Blaster a few times and then use a breaker bar. If it keeps cracking your sockets, upgrade until your sockets are stronger than the bolt.
      It will be easier with the engine hot rather than cold.
      - Ghosty
      WTB: MAP sensor (2+bar), IAT sensor, ECU & dizzy harness plugs... PM me!
      FS: coupe window rain guards, f22a6 intake & ex mani, cams, PT6 ECU, valve cover, dizzy caps, OEM fogs... PM me!
        Got it out, the guy just took a closed wrench and pop, it turns. He said "It's the difference in tools!"
        Well, and I thought sockets owned this world, boy was I wrong.
          Yep after a while you will learn to use alternatives instead of the same ol tools. They either work better or mess you up more. But i would say invest in a decent socket and wrench set since those will come in real handy. If your sockets are cracking its time for an upgrade.
