Ok, hear are the symptoms...the engine runs and pulls fine when cold, but as it get hot the low end starts lagging a bit...also, the engine starts up at the third time or fourth the engien turns over.colud this be the symptoms of a clogged cat?also, the lagging is especialy noticeble in 2nd gear.Highway driving is not affected much.Also, would a clogged cat make me run somewhat lean?cause my sparkplugs are white.I dont have the tools for a backpressure test so i would liek to get soem opinions...
ILBB
EDIT:the car ran rich for a week before i fixed that.
ILBB
are cats welded on or clamped on
