ok i had my buddy change my oil pan gasket to stop the leaking oil, ok its still leakin so now i was told its the rear main seal, it is leaking pretty bad maybe 4q and 3 weeks, and its burning alot off the header i can see some smoke, ok i was wondering if my car can caught fire?
oil leak
at first i was going to mention if he overtightened the oil pan bolts, but that's a lot of oil to be losing in that short amount of time. i would definitely check the rear main seal. the cam seal could be the culprit too I think."the J32a2 should be considered one of Honda's masterpieces..." Honda Tuning, July 2006
i kno the leak your talking about, i've found it today on my accord, i noticed deposit of oil on my fly wheel, either from that seal or from oil leaking from the pan, but by the looks of where the oil is coming from i figured its the main seal, also another oil leak to check for is a front balancer shaft seal at the front of the engine, it may be caused by a dislodged seal on the front balancer shaft. To check the seal, you’ll need to remove the crankshaft pulley, the lower cover, the timing balancer belt, and the front balancer shaft pulley. If you find oil leaking from the seal, replace it.Originally posted by pretty_ricky302i no the leak is right next to the tranny in the corner, like he had to take off a piece of tranny casing to see it better, so is this the main seal area
93 Accord- SOLD
94 Civic- F22a1 Swap, current DD
