I have a list of sensors and what not and where they are found.
ABS Control Unit (Coupe and Sedan): Right side of trunk, behind wheel well
ABS Control Unit (Wagon): Behind Right side of rear seat
ABS Modulator Solenoid Unit: Right rear corner of engine compartment, near under-hood fuse/relay box
ABS Motor: Right front of engine compartment, below battery
ABS Motor Relay: In under-hood ABS fuse/relay box
ABS Pressure Switch: Right front of engine compartment, below battery
A/C Compressor Clutch: Lower left front of engine, in A/C compressor assembly
A/C Compressor Clutch Relay: Left front corner of engine compartment, on inner fender panel
A/C Diode: Left front corner of engine compartment, taped to harness
A/C Pressure Switch (Dual): Left front of engine compartment, behind headlight
A/C Thermo Switch: Behind right side of dash, on A/C evaporator
Alternator: Lower left front of engine
Automatic Transmission Control Unit: On right front of floor, below carpet
Auxiliary Fuse Holder: On left kick panel, on right of under-dash fuse/relay box
Back-up Lights Switch: Center of engine compartment, on transmission
Blower Motor: Below right side of dash, in blower assembly
Blower Motor Relay: In under-dash fuse/relay box
Blower Motor Resistors: Below right side of dash, in blower assembly
Brake Fluid Level Switch: Left rear corner of engine compartment, in brake fluid reservoir cap
Brake Light Switch: Below left side of dash, on brake pedal support
Brake Light Sensor (Inner): Left rear of cargo area, in front of taillight
Brake Light Sensor (Outer): Right rear of cargo area
Bypass Solenoid: In engine compartment, below intake manifold
Chime: Behind left side of dash
Cigarette Lighter Relay: Behind left side of dash, near kick panel
Clutch Interlock Switch: Behind left side of dash, on clutch pedal support
Clutch Switch: Behind left side of dash, on clutch pedal support
Condenser Fan Motor: Left front of engine compartment, behind radiator
Condenser Fan Relay: Left front corner of engine compartment, on inner fender panel
Coolant Temperature Gauge Sender: Right front of engine, below distributor assembly
Coolant Temperature Sensor (TW): Right side of engine, below distributor assembly
Coolant Temperature Switch A: Right rear of engine, in coolant inlet
Coolant Temperature Switch B: Right side of engine, in coolant outlet
Countershaft Speed Pulser: Right rear of engine compartment, on transmission
Cruise Control Actuator: Left side of engine compartment, behind headlight
Cruise Control Unit: Behind left side of dash
Daytime Running Lights Control Unit: Behind left side of dash, next to kick panel
Dimmer Relay: In under-hood fuse/relay box
Disarm/Beep Switch: On lower left dash panel
Distributor Assembly: Right side of engine
Driver's Door Lock Switch Actuator: Inside lower rear of driver's door
Driver's Door Switch: In rear of driver's door jamb
Driver's Power Door Lock Actuator: Inside lower rear of driver's door
Driver's Power Window Motor: Inside lower front of driver's door
EGR Valve Lift Sensor: Top right of engine, forward of throttle body
Electric Load Detector Unit (ELD): In under-hood fuse/relay box
Electronic Air Control Valve (EACV): Top center of engine
Emission Control Box: Right rear of engine competent
Engine Oil Pressure Switch: Center rear of engine, above oil filter
Engine Mount Control Unit: Behind left side of dash
Engine Mount Control Solenoid Valve: Center rear of engine compartment, behind intake assembly
Fan Timer Unit: Behind Left side of dash
Front ABS Fail Safe Relay (Coupe and Sedan): Right side of trunk, behind wheel well
Front ABS Fail Safe Relay (Wagon): Behind right side of rear seat
Fuel Injectors: Top center of engine, at each intake port
Fuel Injector Resistors: Left side of engine compartment, forward of strut tower
Fuel Pump: Under maintenance access cover, below rear seat
Fuel Tank Unit: Under maintenance access cover, behind rear seat
Headlight Relay: In under-hood fuse/relay box
Heater Mode Control Motor: Behind center of dash, on heater assembly
Horn Relay: Behind left side of dash
Ignition Coil: Right rear of engine, behind distributor
Ignition Key Switch: Upper right side of steering column, on ignition switch assembly
Ignition Switch: Upper left side of steering column
In-Line Fuse Holder: Taped to harness, behind left side of dash
Intake Air Control Solenoid Valve: Right front corner of engine compartment, on inner fender panel
Intake Air Temperature Sensor (TA): Left rear of engine, on intake manifold
Integrated Control Unit: In under-dash fuse/relay box
Interlock Control Unit: Behind left side of dash, near kick panel
Junction Connector A: Ahead of left center pillar
Junction Connector B: Below left side of dash, near center console
Key Interlock Solenoid: Upper right side of steering column, on ignition switch assembly
Key Interlock Switch: Upper right side of steering column, on ignition switch assembly
Keyless Entry Control Unit: Under driver's seat
Left Front ABS Speed Sensor: On left front suspension knuckle
Left Rear ABS Speed Sensor: On left rear suspension knuckle
Left Brake Light Sensor: Left rear corner of trunk, on taillight assembly
Left Horn: Left front of car, behind bumper
Left Rear Door Switch: In rear of left rear door jamb
Left Rear Power Door Lock Actuator: Inside rear of left rear door
Left Rear Power Window Motor: Inside middle rear of left rear door
Lock-up Control Solenoid Valves: Right front of engine compartment, on transmission
Mainshaft Speed Pulser: Right front of engine compartment, on transmission
Moonroof "Close" Relay: Below left side of dash, above under-dash fuse/relay box
Moonroof "Open" Relay: Below left side of dash, above under-dash fuse/relay box
Moonroof Motor: Center rear of roof, above headliner
Oxygen Sensor (DX,LX): Center front of engine, in exhaust manifold
Oxygen Sensor (EX): Under center rear of engine compartment, in exhaust pipe
Parking Brake Switch: In console, at base of parking brake
PGM-FI Electronic Control Unit: On right front floor, below carpet
PGM-FI Main Relay: Behind left side of dash
Power Antenna Motor (Coupe and Sedan): Left side of trunk, behind wheel well
Power Antenna Motor (Wagon): Left rear of cargo area
Power Door Lock Control Unit (Coupe and Sedan): Front of driver's door
Power Door Lock Control Unit (Wagon): Under drivers' seat
Power Steering Switch: Lower left rear of engine compartment
Power Window Relay: In under-hood fuse/relay box
Radiator Fan Motor: Right front of engine compartment, behind radiator
Radiator Fan Relay: In under-hood fuse/relay box
Radio Noise Condenser: Top left side of rear tray
Rear ABS Fail Safe Relay (Coupe and Sedan): Right side of trunk, behind wheel well
Rear ABS Fail Safe Relay (Wagon): Behind right side of rear seat
Rear Window Defogger Relay: In under-dash fuse/relay box
Rear Window Washer Motor: Behind lower left corner of front bumper
Rear Window Wiper Motor: Center of tailgate
Recirculation Control Motor: Below right side of dash, on blower assembly
Remote Control Key Recharger: Upper right side of steering column
Right Brake Light Sensor: Right rear corner of trunk, on taillight assembly
Right Front ABS Speed Sensor: On right front suspension knuckle
Right Front Door Key Cylinder Switch: Upper rear of right front door
Right Front Door Switch: In rear if right front door jamb
Right Front Power Door Lock Actuator: Inside lower rear of right front door
Right Front Power Window Motor: Inside lower front of right front door
Right Horn: Right front of car, behind bumper
Right Rear ABS Speed Sensor: On right rear suspension knuckle
Right Rear Door Switch: In rear of right rear door jamb
Right Rear Power Door Lock Actuator: Inside rear of right rear door
Right Rear Power Window Motor: Inside middle rear of right rear door
Seat Belt Switch: Inside driver's seat belt buckle
Security Control Unit: Behind left side of dash
Security Flasher Relay: Behind left side of dash
Service Check Connector (C444 - 2-BLU): Below right side of dash, at kick panel
Shift Control Solenoid Valves: Lower right front of engine compartment, on transmission
Shift Lever Position Switch: Under left side of console, at base of gear selector
Shift Lock Solenoid: Under right side of console, at base of gear selector
SRS Control Unit: Below center of dash, below heater assembly
Starter: Right side of engine above transmission
Starter Cut Relay 1: Below left side of dash
Starter Cut Relay 2: Below left side of dash
Starter Solenoid: Right side of engine, above transmission
Tailgate Latch Assembly: Center of tailgate
Throttle Angle Sensor: Right rear of engine, behind throttle body assembly
Trailer Lighting Connector (C618 - 8-GRY) (Wagon): Left rear of cargo area, in spare tire compartment
Trailer Lighting Connector (C717 - 6-BLU) (Coupe and Sedan): Left side of trunk, top rear corner
Trunk Latch Switch: Rear of trunk lid, on trunk latch assembly
Turn Signal/Hazard Relay: In under-dash fuse/relay box
Under-dash Fuse/Relay Box: On left kick panel
Under-hood ABS Fuse/Relay Box: Right side of engine compartment, forward of strut tower
Vehicle Speed Sensor: Right rear of transmission
Windshield Washer Motor (Coupe and Sedan): Behind lower left corner of bumper
Windshield Washer Motor (Wagon): Behind lower left corner of front bumper
Windshield Wiper Motor: Left rear corner of engine compartment, under air scoop
Wiper Relay: Right rear corner of engine compartment, behind under-hood fuse box
Under-hood Fuse/Relay Box: Right rear corner of engine compartment, behind strut tower
Hope this helps someone.
