hey i got a rpoblem ..im trying to set my engine back to tdc well...i set #pistin then set my cam gear where it should be , my rotor is facing to the first plug wire on the dizzy so i put everything back together , go to start it and get a big flame that shot out of the inake at the throttle body anyone ever experience this before? if so, is my timing belt off a tooth..and which way should i move it? thanx
intake flame
pull off the timing covers and make sure all of the markings line up PERFECTLY...
crank and front balance shaft have notches, rear balance shaft you use the rear alignment hole, cam gear(s) have horizontal lines that are supposed to line up with the top edge of the head and an arrow that points straight up...
make sure all the timing is perfect, check the firing order of the plugs, and check the dizzy timing...
you can make sure that #1 is at TDC by sliding a wooden rod into the cylinder, you can see it moving up and down as you turn the crank...Last edited by cp[mike]; 05-17-2006, 10:02 AM.
you do know that this is a crx not a cb...i figured since it was still a honda you guys could help better than anyone esle...thanxOriginally posted by cp[mike]pull off the timing covers and make sure all of the markings line up PERFECTLY...
dood.. seriously.. ur timing is off.. if ur fluxuating.. lol.. unless u replaced gaskets or something...
go back..
remove the belt..
put something into the 1st cylinder.. (Closest to the timing belt)... long enought to see it go up and down and u be able to get it..
rotate the crank and wait for the stick or w.e u have in there.. go all the way up once its all the way up (do it a few times).. once u get close it will feel like its floating.. now check the timing gear to be aligned with the block.. once that mark is aligned.. put the belt on from the bottom first and then head upward.. when trying to put the belt on make sure the crank doesnt rotate... if u have the tensioner loosened all the way it should be pretty easy for u to do..
Praise The Lowered...
Originally posted by IBCNYAaight man im gonna try this shit again thanx...
GOOD LUCK MAYNE
MR Thread:
ok try this by the book again ..all marks set where they should be
#1 tdc...cam gear where it should be ...rite lets crank this bitch i mean i took three hours carfully over and over checking this shit out making sure its where i need it ....turn the key i get one poof from the engine then nothing ..its getting fire i pulled the plugs they re ok..wires getting fire wtf is going on...its not this hard...
some body think my timing belt may be a tooth off??
can you help me out here?
Check your firing order.
ive seen intake flames when plug wires were switched around. i mentioned checking the firing order in my post... did you check and double check it yet?Originally posted by NAiL05Check your firing order.
