heres a riddle for you guys what are possible ways to get gas in oil...example car wont start and oil dipstip reeks of gas...example its dripping off tha stick!!!
what do you do>>>a. tear down the engine or b. shoot the asshole who sold it to you dont kill him but shoot him in the leg just so he knows he fucked up...this is bullshit im trying to figure out how i used to gallons of gas in to days trying to get my car to start for two days...guess what i damn sure didnt burn it off nope i think is all sitting in my oil pan..any suggestions?
You answered your own question. When you flood your engine that is what happens. Fuel keeps getting delivered to the combustion chamber via injector, but no combustion possibly(cause of fault in ignition system) results in fuel collecting ,then bypassing piston/piston rings down into crankcase. I'm going to assume that you have no cel? Because if you do then you should probably start there. Tell you what. If it wont start after..... say 6... cranks, it probably wont start so why continue cranking?
Once/if you figure out your problem get some gumout engine flush,oil, and two filters. drain your oil,replace with engine flush,put new filter on, run flush for ten minutes, drain flush,remove filter, add oil
