I was reading up on how our automatic transmissions work, and it says that in D4, lockup is used on 2nd, 3rd, and 4th gears. In D3, lockup is present only in 3rd gear (4th is not present obviously).
Please correct me if I'm wrong, but "lockup" is the enemy of power in auto's, right? So, if you want the maximum amount of power out of the transmission, from a stop you should leave it in D3 until the end of 3rd at which you should then switch to D4, thereby avoiding lockup in 2nd gear. Gearing manually from 1-2-D3-D4 would not be anymore beneficial (in terms of avoiding lockup).
I read that lockup is used to increase gas mileage, and therefore I assume it decreases power.
Accelerating from a stop while leaving the selector in D4 would use the lockup in 2nd, 3rd, and 4th gear, which would result in slower accelerating.
Is any of this correct, or am I an absolute idiot? Or both? LMK and TIA.
