whats up guys i need a little help before i send the car to a shop,i'am having trouble starting the car,it does not matter if it's cold or hot,the problem is when i turn the key it wont start till like the 10th or 20th time of turning the key.and when it starts up it sometimes struggles or sometimes it starts right up with like the second or third try.now i have already changed the battery six months old,alternator one week old,main relay one week old,and starter about one year ago.also when i'am driving and i turn on the lights the radio cuts off but it turns back on quickly and i just started getting a cel code 43 yesterday.do you think the starter is bad (it is used ) or the fuel pump is going bad,what about the distributor or maybe should i change the fuel pump relay? any suggestions would help and thanks!
starting problems (cel code 43 )
Tags: None
The power flicker sounds like bad wiring perhaps...
how's your timing, fuel pressure, etc?
Sounds like it needs a tuneup.
Code 43 is fuel supply
So I'll ask again for you to check your fuel pressure...........perhaps its just the fuel filter, but it could be the fuel pump.....43
Fuel Supply System
Defective or malfunctioning Fuel Supply System
http://media.honda.co.uk/car/owner/m.../400/6-209.pdf
http://media.honda.co.uk/car/owner/m.../400/6-208.pdf
I am studying the issue as I make this post.....
The code 43 is also often a result of a malfunctioned O2 sensor, you may look into replacing that if you haven't done so already.
The service manual I have on this PC refers to the H23 engine, but I believe you can cross-reference without trouble. If these pics are unsatisfactory I may be able to email you some higher res ones later.
