Does anyone know of a shop somewhere out west that knows 90s honda manual transmissions and rebuilds them? I've done it twice and gotten it either a little or badly wrong both times and i need pro help.
West Coast Transmission Rebuilds
1991 Accord Lemons Race Car, "The Minnow" RIP
1993 Accord Lemons Race Car, "SpaceEx Starship"
Neuspeed Race Springs, Koni Sports, Acura CL Rear Sway Bar,
Adj Upper Control Arms -3.0deg front, -2.0 deg rear
M2A4 Trans, Cusco 1-way Limited Slip Differential, Stage 2 Clutch and 11lb flywheel. A4 Header, 2" exhaust all the way back, catalyst delete, delta 262 grind, glasspack muffler, PT6 ECU.
Acura CL3.0 Brakes Front and Rear, Raybestos St43 Pads, Redline 600 Brake FluidTags: None
I could try to contact Syncrotech in San Dimas and see if they can help.
Syncrotech
581 West Covina Boulevard, San Dimas, California 91773
(909) 592-5900
You could also possibly contact Werdwerx in Anaheim. I'm pretty sure he is a member on here as well.
I've bought all my rebuild kits from them. I guess it didn't occur to me that they do the work too. That's a good suggestion, thanks.==========================
- 1 like
