Any experience with this tool?
    i just found this tool and i was wondering if anyone has it or has used it and if its worth buying http://try-intools.com/index.html
    haha...looks like your trying to promote their tool ...hey if you are..promote away...
      Hmmmm, well if it really works that easily without damaging other parts....soungs good.
      But, the problem is that I don't think that the bearing assembly is supposed to come apart!! It's a sealed unit, "Grease the bearing, and re-install the hub...." I don't think so Tim. Their video SHOWS the bearings clearly exposed. So basically, the hub/bearing assembly will no longer support the wieght of the car without the axle install, and the nut torqued.......thereby HOLDING the bearing together on re-assembly.
      Does that sound about right? Someone chime in if I'm off-kilter please.
      1992 Accord LX - SOLD
        From what I have heard, all that use it like it. I never looked at how it worked since I dont have to worry about it anymore. But I am sure someone has to have used it before.
          i never thought using a slide hammer was that difficult
            was...i bought a slide hammer the other day to pull EGR plugs, i wonder if i can use it for this
              I've always taken the spindle arm off and used a press. You don't have to mess with any suspension alignment angles and you get a good chance to check the bushings and all that good stuff. It may take longer but I don't like the way the tool pulls the bearing apart. I've never used it tho so I couldn't tell you for sure. It may save a mechanic time but may cost the owner more in parts down the road when the bearing goes bad and has to be pressed out anyways.
              My Accord History:
              91 EX 2dr : 91 EX 2dr : 91 LX 4dr : 93 EX 2dr : 86 LXi 2dr : 92 LX 4dr : 92 EX 4dr
              -Patrick
                That tool is great, it makes the job take less than 1/2 the time it normally does.
                I got it for work one day and am damn glad I did, worth the 200 bucks.
                1991 Honda Accord, 2.2L I4
