its simple,its located on the firewall behine and below the pfi,take your gas cap off to relieve pressure,undo the banjo bolt,and the other bolt,there sometimes very hard to remove ,so use lube.replace the old washer,and filter.tighten down the bolts,and replace gascap.
u have to remove the vacumn control box and sometimes the air intake tube. counter it with another wrench when u remove it though...
