anyone remeber this thread about my fuel stopping in the middle of driving?
http://www.cb7tuner.com/vbb/showthread.php?t=49942
The same fuse that's on the line where that short that was the problem in that thread is now blowing constantly (this is #4 underdash, runs to reverse indicator lights and main relay terminal #1). I ran a straight wire with a fuse holder from the battery to terminal 1 on the main relay, and it's still blowing fuses, only a 20 amp will hold, which is double the rating. So, that eliminates anything with the reverse lights,which means something on the main relay somewhere is demanding too much energy, but I've got to be sure before I go dumping money, I havn't got much left. The 2 things that draw power from the main relay are the ECU and fuel pump. Everything else is a ground or puts power into the relay. I swapped out the ECU and it didn't fix anything, so I'm doubting it's drawing too much. That leaves the fuel pump, but it's still priming when it should, not making odd sounds... it seems odd that it would be the problem... but could it be? Or considering the situation, should it be?
Also, the guy at pepboys said that 4th gen Prelude and CB7 fuel pumps are different, can anyone verify that? Because if they're the same I can get one at a junkyard for $20, if they're different, then... well there are never Preludes in junkards so I get to spend millions for a new one...
