I Read My Heynes Manual Book And It Does Not Tell Me Anything About A Code 43 Has Some One Runn Throught This Before Hit Me Up Please
Check Engine Light On Code 43
code 43..........Fuel supply system......problem with 02 sensor circuit or fuel system. got that from Mitchell on Demand. you could be running lean (87 oct) use higher octane and see what happens. your number one problem is the o2 sensor is starting to die. i would go with higher octane first, see if the light comes back on, if it does change the o2 sensor. if it doesnt come on happy motoring. but i would still change the 02 sensor, dont forget to clear the code. pull the radio back up fuse in the engine bay. a red 7.5 amp
i was getting a 43, ran a can of seafoam through the intake and put a whole bottle of fuel system cleaner in the gas tank, and i never saw the code again
iam thinking i do have a fuel supply problem because sometimes only sometimes iam on the accelerator and my car stummbles like it doesnt wanna go so i let go of the gas pedal and hit it again and its fine and iam going to start using hight octane fuel i usuallly purchage my fuel al chevron so ill see next week whats up thanx guy ill keep posting
by the way where did u guys find the answer to the code because hayns does not say
whens the last time you changed your fuel filter? stumble on acceleration is usually three things i can think of
1)- clogged egr ports and valve
2)- clogged or dirty fuel filter
3)- car needs a tune-up i.e plugs, wires, cap, and rotor.
other factors
intake manifold leak..i.e gaskets or vaccum hose leak
bad sensors like tps, or coolant temp sensor, or oxygen sensor
throttle cable out of adjustment
good luck x
Originally posted by f22-dohcare u using the code from the proper motor? i made that mistake, i have a lude motor but followed an accord code thing....
the only difference i would see in any motors are the egr/vtec codes. some hondas dont have egrs and as everyone knows, not all have vtec.
for bajaccord
what do you mean custom fabbed? maybe your sending unit is bad or your fuel pump is going or screen is dirty. do you have upgraded injectors? maybe going around the tight corners is moving the gas away from the pick-up? please elaborate. maybe your main relay is going on the fritz?
goodluck x
nice set-up bajaccord..what fitting did you use for the fuel pump adapter, and whered you get it. cuz i need to custom fab a fuel line.
just idea again..maybe since your runnnig turbo. you can try and run 8an line. maybe there a temoporary lag in fuel geting to the rail and the 6an line isnt enugh for the turbo. or remove the pulse dampener, or install it if you dont i dunno. just throwing ideas?
regardsLast edited by xfactortype1; 07-08-2006, 08:02 AM.
Originally posted by dynamic93iam thinking i do have a fuel supply problem because sometimes only sometimes iam on the accelerator and my car stummbles like it doesnt wanna go so i let go of the gas pedal and hit it again and its fine and iam going to start using hight octane fuel i usuallly purchage my fuel al chevron so ill see next week whats up thanx guy ill keep posting
sounds like a fuel pump to me
(\__/)
(O.o )
(> < ) This is Bunny. Copy Bunny into your signature to help him on his way to world domination!
