Cerametallic will last longer and bite a little faster, but unless you are making 300+ HP, the stock clutch and pressure plate will work fine, and cost quite a bit less. Which flywheel are you using? The one from the F22 or the H22? The H22 actually uses a smaller diameter clutch, so it actually can't handle as much power as the F22 clutch. The best way to go would be a lightened flywheel that is designed for the F22, with the stock clutch for the Accord.
Visit us at http://www.valleyspecialists.com for all of your Honda and Acura service needs!
