Ok, I installed new main bearing in my H22A4 and everything went fine, when installed the rod bearing caps I checked the torque specs and it said to torque them to 34 foot pounds so I did, but now I cant turn the crank with my hand any longer. I thaught that the crank should move freely, maybe im not strong enough or something or do you guys think its torqued to tight or is everything fine.
Need Crank Help!!!
Did you snug them down and tighten them in the correct sequence? Start with a 3rd of the amount and move up to the final aka. 34ft/lbs. Start from 11ft lbs, 22 ft lbs, 34ft lbs final. The sequence you torque them in is pretty important. You lube the journals and such where its suppose to sit?
