The down pipe from my header is 2.25" and I'm looking to get a catback and hiflow converter that is 2.5". My question is will I be able to fit the 2.5" pipe with the 2.25" pipe from my downpipe? Do they weld it? I'm just not sure because I don't want new headers, but I want to upgrade my exhaust. Thanks
exhaust question
If you are planning on boosting and you aren't even sure about this, you have a loooot of homework to do. The downpipe will go all the way to your cat converter anyways, so you just get a regular exhaust and hook it up to your headers as is. Ie your two peice headers, including the bottom peice with the flex pipe will remain until you put on the turbo and downpipe. what you are refering to now is your second half of your headers, it's not really a downpipe. Your second header peice will NOT hook up to a turbo.
I realize where the downpipe from the manifold ends and I realize that the second half of my header will not hook up to my turbo manifold...all I am asking is can a 2.25" pipe hook up with a 2.5" pipe. I'm not talking about anything else except that question. ThanksOriginally posted by SmokinspeedsIf you are planning on boosting and you aren't even sure about this, you have a loooot of homework to do. The downpipe will go all the way to your cat converter anyways, so you just get a regular exhaust and hook it up to your headers as is. Ie your two peice headers, including the bottom peice with the flex pipe will remain until you put on the turbo and downpipe. what you are refering to now is your second half of your headers, it's not really a downpipe. Your second header peice will NOT hook up to a turbo.
You need something that will expand from 2.25-2.5 BUT if your going turbo you should be making a custom downpipe thats 2.5 since it will be 10x easier. I would say fab anything after the turbo hot side it just requires soem pipe bending and welding that an exhaust shop should be able to do for you. Oh yea and Did I say go custom on the complete system? Kteller has a mandrel bent piping kit a bit expensive or you can go to a muffler shop as I mentioned while fabbing the downpipe.
