hey everyone. ok i had changed my passanger side cv shaft cuz it was really messed up and both my inner and outer tie rods. then i put my rims on and i had got my car aligned. but i now noticed that the driver side alignment is also messed up so i got to change that also. but i was wondering. will i have to get it re aligned after i change the cvshaft? cuz i know the tie rods are the main things of changin. but will i have to redo it again?
CV shaft. Alignment??
technically, NO, it shouldn't be out of alignment after swapping an axle BUT it is 100% possible that it's not aligned the same as it was.....it's safe to always get an alignment after major front end work where parts are taken loose, but, that's up to you.......1/10 people actually get their car aligned/checked as often as they should (2x per year)......i'd have it checked....and on the 7th day, deevergote rested and called his mom.
