Is there a way to check a MAP sensor to make sure it's good. I'm still throwing the code after trying three different sensors. It is possible that all of them are bad so I'd like to know for sure if they're working or if the problem is somewhere else. Thanks.
How to test MAP Sensor?
I read somewhere that marijuana effects the memory. For some reason I can't seem remember where I read that. -- max sideburn(aka torqstr)
"Those who would sacrifice liberty for security deserve neither." - Benjamin Franklin
CB7: The Movie TEASER VIDEO
Tags: None
sounds like a bad wire (VERY easy) but are you clearing the code after you put the MAP on?Originally posted by TorqstrIs there a way to check a MAP sensor to make sure it's good. I'm still throwing the code after trying three different sensors. It is possible that all of them are bad so I'd like to know for sure if they're working or if the problem is somewhere else. Thanks.
i looked forever trying to find the voltage readings but found none......i have an extra map in my snake room that you can have for whatever shipping costs from 35611 if you need it....i bought it a while back, didn't need it and it's just here........
but they normally DON'T go bad.....it's actually very rare, usually a vacuum or wiring problem.....i had a skinned wire once and i tried everything and finally found the skinned wire....and on the 7th day, deevergote rested and called his mom.
