So, before y'all jump to conclusions about it being the FITV or the IACV or a Vacuum leak, please read all the symptoms.
Car (93 LX, 5 speed, with p12 ecu) has always run great till this weekend. Took a 125 mile trip to the ocean, idle was really high (1200RPM) when I got there. When I got back (another 125 miles) and got off the freeway, I stopped and the idle started searching back and forth between 1000-1500.
Figuring it was the IAC or the FITV I checked both, and neither is leaking, and both work correctly. So, I decided I would just turn the idle down via the idle screw. Turned it WAY WAY in to get the RPM back down to 700 +-50. After doing that, the car no longer lopes.
The only problem is that it now runs much rougher than before, and there is a noticeably louder whine coming from the intake. When it was searching back and forth, there was a horrible whine and gurgling sound coming from the intake. WTF?!
