Cant get into reverse!!! NEED HELP ASAP!!!!
    alright guys....I've actually been puttin up with this for quite a while now. Well, I grinded 3rd one day only to find that I could not get into reverse afterwards while parking. The shifter feels as if its blocked off from reverse, and i could not even get the tranny arms into reverse either Anyone know what it could be? What parts would be needed? How do the gears shift over to reverse? thanks for any help peeps
    Formerly 91AccordExR33
    11.68 @ 127mph
    417whp/375wtq
    Sold: 8/2016
    This is a waaaaaaay longshot, and not likely to work in your situation if something is actually broken, but it's nearly 3 a.m. so why not?
    Every Honda manual tranny I ever had always went into reverse much easier by first going into 4th first and then reverse.
    Sort of like an upside-down U-pattern: 4th-to-reverse in "one motion."
      Yep as decked mentioned try poppin it in 4th if not 1st then go to reverse to see if it goes in. If it doesnt go in and as you said the shift arms wouldnt budge you could have busted synchros. But you know what your fluid level is sittin at?
        hold the shifter into R and SLOWLY, barely start to let the clutch out, see if it pops in once you get the gears moving..
          yeah...try doing what was mentioned....DO NOT FORCE IT into reverse...baby it!!!
          putting it into one of the gears first...helps loosen up the gears before going into Reverse!
          MR Thread:
            I had this problem when I first got my car man.You might have a dragging clutch. With most clutches the release interval is about 4 to 5 seconds. do this man. start your car and let it run. Let it get up to its normal operating temperature. With the engine idling and the tranny in nuetral, press the clutch pedal to the floor. Hold it for 10 seconds. Then shift it into reverse. That 10 seconds should have been enough time for the clutch to come to a complete stop, allowing a shift into reverse without gear clashing/grinding. If it grinds it means that your clutch is dragging. Not releasing completely. That might mean a bent disc, or rusted tranny input shaft. just a guess.
              damn thats not good
                i'll try all of this and get back to you guys, thanks!
                11.68 @ 127mph
                417whp/375wtq
                Sold: 8/2016
                  If none of those work, you might have bent the shift fork or bent/misaligned the shift holder. R doesnt run off of a synchro; it works by moving an idler gear in between the two other gears(on the 5th gear synchro ring and main shaft).
                  -Kevin
                  1988 Honda Civi- D15B VTEC Dac Biet, my "race car"
                  1992 Honda Accord LX: DD until I finish school
                    wait...E...yo..you had that problem with your first clutch???? damn..how come you didn't tell me????? yeah..thats BAD problem!!
                    MR Thread:
                      dragging clutch can be fixed by adjusting the pedal, or fixing whats wrong with the hydraulics (bad master cylinder possibly)
                        Best case scenerio. I was speaking from my own experience. Mine happened to be a worst case scenerio. However the release system is operated by hydro pressure. So you are also right.
                        Of course we completely overlooked the tranny itself.
                          well holding it in R while letting the clutch out didnt work....i hope its not a shift fork...
                          11.68 @ 127mph
                          417whp/375wtq
                          Sold: 8/2016
                            You say all gears go in fine right but reverse....You sure nothing might be snaggin the linkage in the engine bay if not shift linkage bent a lil if not could be something internal.
