hey, i have a problem...i can start my can and put it in gear and it goins in just fine,but as soon as it warms up a little it will not shift it acts like its in neutral..but i can shut it off then start it again and it shifts and the problem comes back now i have put 2 used shift silaniods on and that has not been my problem now i think its my tcu i could really use the help cause this is my only means of transportation....HHHHHEEEEELLLLPPPPPP!!!!!!!!!!!! !
Tcu
can it be the contact area for the shift silinoid under the shifter assembly?
does it just not shift out of park or when u put it in gear u get nothing and feel as though ur in neutral?What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Hmmmmm, sounds exactly like when my auto tranny took a shit on me. It turned out the tranny had a shit load of shavings in it. What wold happen was that when it was cold, it would shift but when it warmed up, it would just go into neutral. The reason was that the shavings got clogged up in one of the filters (forgot which one) and this would prevent the tranny from shifting. But, this probably isn't your problem. But, be weary of it."I'm out for presidents to represent me"
