Ok this is going to be fairly lengthy. Any help would be appreciated.
Background:
Bought my 92 CB accord last year around April. It had already had a h22a swapped in and an auto to manual swap done. When I bought it, it was making a squeal noise, sounded like tyres spinning, whenever I engaged the clutch. Mostly when taking off. But also 1st to 2nd sometimes.
Got the clutch and flywheel changed about sept last year after a mechanic saying the noise was probably a dead clutch. Also it started slipping after a while. The mechanic that changed it for me said the clutch was actually in ok condition however the flywheel was cracked.
Anyway. The noise stopped after this and everything seemed ok. However. Ever since I bought the car the clutch seems to engage a long way out on the pedal travel. With the old clutch and the new one.
Currently:
Clutch has now done just under 25000k's. Lately it has been feeling like crap. Feels like it is engaging at the very last second. I bled the fluid a couple of weeks ago. This seemed to help a bit. But it still seems like there is an underlying problem. This was highlighted when I drove a friends civic last night with a hd exedy. Mine is supposed to be a HD Clutch Specialties but when I got back in mine it felt like slush.
Could it be possible that the slave/master cylinder ratio's are wrong or something? And therefore isn't allowing the pressure plate full range of movement? Could the clutch be dieing already?
I bought the car knowing it was going to be a project. But when you don't know what's wrong in order to fix it. It is just frustrating. I would really appreciate any suggestions. Next stop when I get some money is a clutch specialist.
Thanks.
Background:
Currently:
Thanks.
