pleaze help me guys...........
    guys its time my idle stopped.....know ive tried everything but my baby revs it from o- 2000 rpm and its really making me sad to see my baby in pain.....know when i mean i tried everything i mean everything....i even tried taking it to a damn honda specialist and he didnt even know what it was wrong with it he said the the valve might not be on time but i doubt that that the problem......well guys please give me some strong advise so i can cure my sweetheart please help me!!
    can someone please help before i send this cb7 to the grave yard i have a erratic idle no codes i replaced my tps switch,my iac,coolent temp sensor,plugs,wires,cap,rotor. i give up no vacume leaks i replaced all my lines,wtf.i cant be the only one to ever have this problem ive spent over 50hrs under the hood and i cant find the problem and mechanics i brought it to cant figure it out its not the head gasket its not the intake gasket,what the hell is it just 1 day these cars do this and there no good or what.when i erratic i mean 1,000 to 2,000 rpm every 5 seconds it used to idle at 850rpm (does this sound like your problem???)
    ____________________________________
      )if that sounds like your problem check this....)well each time i steped on my brake it drew vacume and raised the idle and i had white smoke so i figured i would check all vacume lines they were good so i took a bottle of throttle body cleaner and began spraying every where till i got to the manifold gasket the idle changed so i sprayed somemore what do u know the was a million bubbles and the whole gasket is not even there it must have dissinigrated from a previous leaking valve cover gasket well my mechanic is gonna hook it up real proper 75 bux labor cant beat that.12 bux for the gasket at autozone ill be keeping my ride and pimping her out afterall.
      this was 4doorex93's problem and thats how he fixed it.or is getting it fixed.
        do this. disconect all the SENSORS except the colant sensor. and the open the valve on the right side of the throte body. see if that helps.
          almost forgat. try to put a thread at www.honda-tech.com they know a lot of stuff about honda engines.
            spray throttle body cleaner where ur intakemanifold bolts to the head if u hear a difference in idle and see alot of bubbles its ur intake gasket i just went through the same problemb.
              aight im gonna try all of this today hopes it woprk thanks for your help guys ill let u know if it works tonight
