Hey guys,
My problem is very similar to the one in this thread:
http://www.cb7tuner.com/vbb/showthre...hlight=starter
only there are a couple differences.
Basically, I was having issues for a while with starting my car. It would sporadically not start. Some of the times when it didn't start, cleaning out my battery terminals would fix the problem and it would start again for a few weeks before the problem came back. A few months ago my alternator went, so I replaced that and had no issues for a month or two, then about a month ago, it wouldn't start sometimes when it was parked for a while in the middle of the day. I thought it was the main relay because it would start at night with no problems. Some of the times fiddling with the battery terminal would fix the problems, other times it wouldn't start no matter what. The heat wave ended, I lubed up the terminals good, and there hadn't been any issues for the last 2 weeks (so I never even fixed the main relay because it was starting fine again).
Then 1-2 days ago, my car sounded like it was struggling just a bit to start. I don't know how to describe this, but it was subtle enough to maybe be a coincidence, but it was obvious enough that I really wasn't surprised when I tried starting my car last night and it didn't start. I get power, AC, lights, etc, but when I turn the key it clicks once and that's it, doesn't turn over, doesn't struggle, doesn't do anything. I tried cleaning the terminals and it still didn't start. Then tried boosting it and still didn't start. Called a tow truck, he came, said it sounded like the starter. After a while, he messed around with the terminals and it started. He had me turn it off (big mistake) and then try again and this time it didn't start and hasn't started since, no matter how much he or I messed around with the terminals. I had it towed home last night and this morning while trying to get it started, I can definetly hear a clicking noise coming from the starter (when I turn it off all the way and then try to start it). The tow truck driver had tried hammering the starter, and I tried again today, and it didn't start either time. So now I'm really damn confused.
- power to accessories is fine, but can't start
- boosting does nothing
- messing with the terminals caused it to start one time, but this may have been a fluke as boosting it didn't work and messing with it countless other times did nothing
- click noise comes from the starter
- hammering the starter does nothing
So sounds like the starter right? Or maybe the cable going from the battery to the starter? Anything else I can check?
Any help's much appreciated.
