external distributor
    i need a new dizzy for an jdm h22. the one i have was internal coil but i want get an external dizzy so i can get my msd. So my question is what else besides the blaster coil do i need to put it on. And ya i did a little search and don't find what i needed.......thanks for the help
    "Know Your Rank"
    Internal/External Coil Issues:
    If your car came equipped with an internal coil then the JDM H22 distributor will plug right in no problem. However, if your car had external coil then you will have to modify one plug. The plug you will need to modify is the plug that went to the stock coil. There are is a yellow and a yellow/black wire, splice those 2 wires together. The Black/White wire is useless, don’t worry about it. If you dont want to cut the plug off and splice, jam a 30amp fuse into the end of the plug, making the connection between the two wires.
    If your car is external coil and you wish to maintain the external coil you will need to open the JDM dizzy, remove the internal coil. Run the wire from the igniter that used to go to the internal coil out of the distributor and plug it into the blank spot on the distributor’s plug. That’s it. Use the 93-95 Prelude Vtec’s Distributor cap and rotor that you can pick-up and your local dealer or auto parts.
    Its right in the swap faq to convert if you didnt know.
      ok so since i'm getting the whole dizzy with the msd cap. all i have to do is spice those two wires....i hope i'm gettin this right
      "Know Your Rank"
