key/ignition issues
    key/ignition issues
    this has been goin on for a while, never though anything of it because the car isnt being driven right now..its on jack stands actually
    but the key will not come out of the ignition
    the car is engaged in park, ebrake is on, idk what it oculd be
    the left side brakes are disassembled right now, could that have anything to do with it?
    i need some help, just so i cant get the key out..i know its not "stuck" , its more like the lock is still on it..
    -- Check out my CB -- My CRV blackhousing thread!!-- My CG coupe--
    Turn the steering wheel a lil? Force it into park again lol might work sometimes its not really locked in and the key wont come out.
      ok well i went out to realize turning the wheel couldnt fix anything
      i knwo the car isnt engaged in park because the wheel isnt even locked
      the shift lever is all the way in park position and everything, the key will not come out
        is the car turned off and if so your ignition switch prolly locked up easiest way to get the key out is gonna be to take the whole cylinder out and replace it leave the key in the lock for the moment the 2 cap screws on the colum have top be tapped out then the key has to turn for the easiest removale
        the build and demise
        buy stuff i want a new car
            Check the steering column lock (prevents the wheel from turning unless the key is in the ignition). If it is okay, then next suspect the insides of the key lock. Spray some oil (spray can works best) along the key into the insides of the lock. Better oils to use are solvent/oil types (liquid wrench being one).
              i know for certain its not jammed or stuck in there
              the key lock is engaged, you could just tell
              the wheel is free rutning becase the key is in it, im just thinking its reading the brakes being off and considering the car not safely in park
              could that be even close to what the problem is/what the problem is related to??
                Go ahead and try the oil process first, it won't hurt. You gotta realize that when the insides of a lock get no lubrication, it can freeze in place. Just like the winter time. So go get some of your oil in there.
                  i went out and tried some wd40, but nothing new
                  it jiggles just like a key wol=uld with the lock still engaged
                    ahh i had this kind of problem. its really sucks bro. our cb7s are know to have sometimes sticky ignitions. it take quite a bit of force to take it back out. but after you do, just use some tight bolt losener spray into the ignition. it should fix up sometime soon. good luck.
                    miss my turbo cb7
                      i believe i stated this already once "REPLACE THE IGNITION SWITCH"
                        yeah i heard that
                        its just i dont see how it just goes bad when i havent used the car in a year
                        its in the middle of a rebuild-type deal and we've been working on it
                        key and ignition has always been fine
                          it's kinda like this...if ya don't use it, you lose it. like everything else in the world, ya gotta use it to keep it working good. your brakes don't have anything to do with it. just my lil ole $.02
                          If you're gonna go, go with a smile!
                          Current vehicles: 2006 Pacifica Touring Inferno Red (the Wife's) - 30k
                          1993 Accord EX - optima 'red top' battery, magnaflow exhaust, tinted windows - My $500 ride w/ 217k miles
                          2004 Suzuki GSXR750 - Racetech sus f/r. Dunlop Qualifiers. clear Puig DB screen. my drug - 7500 miles
                            do u have battery power....isnt the key lock on the steering column work only if u have battery power??? and the gear in park or neutral???
                              i have a dead cell in te battery, so we're replacing it
                              but we have charged it for enough for it to stay alive for a few hours, same thing
                              and the car is engaged in park, unless for some reason its reading its not, which was what i was looking into
