adjusting jdm heads
    adjusting jdm heads
    are those circle knobs used? i tried moving them and they dont move. i didnt want to force anything and brake something.
    uh... what the hell are you talkin about?
      headlights
        they hold the lightbulb in place. They don't adjust if it's what i think your talking about.
        Noobie my ASS.
          those little wheels are adjusters. the plastic lip that surrounds the wheels shoudl have a notch in it on either side- stick a flathead screwdriver down thru the slot and under the \/\/\/\/ shaped wheel, and turn the screwdriver to rotate the wheel.
          yes, those are adjuster wheels which one u should use, i have no idea.
            the upper wheel right above the inner h1 lights is for the horizontal adjustment of the h1 foglights
            the big lower wheel in the middle is for the horizontal adjustment of the h4 headlights
            the little tiny wheels on the end corners are for the left/right adjustment of the h4's
            My members ride thread
              coo thanks. i never would have thought to stick a screwdriver underneith the wheel to turn it.
                you should also use a phillips head, not a flat head..
                  Originally posted by fliplyricist1
                  h1 foglights
                  h1 highbeams
                  HSHO #3
                    Originally posted by 93accordEX
                    h1 highbeams
                    h1's foglights lol
                    at least that's how I've heard what they're supposed to be used for in japan the h1's are foglights and the h4's double as the low/high's (just like other typical cars like Maximas that use H4's for both lows and highs)...I'm trying to wire mines up like that...just gotta connect the higher filament lead to my high beams...just been lazy lol
                      well I hope I never pass you at night with your "fog lights" on
                      HSHO #3
