safe mode
    safe mode
    i just did a motor swap and i fixed all the check engine lights the timing and the tps sensor but when i go drive it if i floor it i hit fuel cut at 3200 rpm if i give it 1/4 throttle it cuts at 6200 rpm i am using stock p13 ecu also after i have aplied load to the motor when i put it in neutral the rpms hold at 3000rpm till i put on the brakes and stop plz i need help really bad and im getting major bummed out
    solved upon closer inspection the egr valve gasket wasnt good and neither was the tps sensor gasket or tps sensor i just throught i didnt know how to use the volt metre so a guy came over and said i was doing it right and so i figured what the hell i just check and see if it says the same thing with my tps sensor from my old motor so i riged it up made sum gaskets and whatayah know the tps sensor was bad and now i got mad vtak yo!!!!!!!!!1111111111!!!!!!!!
